Help to het riding
Start a Ride here...
User avatar
Rexr650l
Help to het riding
Postby Rexr650l » Sat Dec 30, 2017 4:49 pm
So I just did oil change and decided that after 6000mi it was time to adjust the valves did all that and now there is a very loud ticking noise coming from the top of engine any suggestions on where I can take it I've scared myself enough already thank you guys
User avatar
mark_hochman
Site Owner
Re: Help to het riding
Postby mark_hochman » Sat Dec 30, 2017 5:49 pm
where are you located
User avatar
Rexr650l
Postby Rexr650l » Sat Dec 30, 2017 7:16 pm
North Hollywood by the 170 and roscoe
User avatar
mark_hochman
Site Owner
Postby mark_hochman » Sat Dec 30, 2017 7:32 pm
Not that it will help you tomorrow but there is a Honda dealer in Santa Clarita, called Ken and Joes. I would not ride it if it’s making noise.
User avatar
Rexr650l
Postby Rexr650l » Sun Dec 31, 2017 8:05 am
Thank you will give them a call next year hahaha, so I started the process over again, the sound level did decrease, sounds like an exhaust valve,I am adjusting to specs from a 93' manual since I can't find numbers on a 2017 anywhere
User avatar
mark_hochman
Site Owner
Postby mark_hochman » Sun Dec 31, 2017 10:33 am
you should be able to get the specs on Thumper Talk https://thumpertalk.com/discover/unread/
User avatar
mark_hochman
Site Owner
Postby mark_hochman » Sun Dec 31, 2017 10:45 am
User avatar
ahdoman
Postby ahdoman » Sun Dec 31, 2017 12:59 pm
Make sure you're really at TDC! With the valve cover off watch the intake valves open then close. That should put you close to Finding the TDC mark (it might be on the cam gear). You'll need to use the current spec. The newer engines run much tighter tolerances.
2015 EXCF350 & Cagiva Gran Canyon
Users browsing this forum: No registered users and 2 guests
